Use this guide to replace a Galaxy Note II midframe.
Grasp the end of the stylus and remove it from its slot in the midframe.
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
Lift the rear case by the corner nearest the divot and remove it from the phone.
If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Remove the microSD card.
Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
Remove the battery from the midframe.
Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
Slide the plastic opening tool down the seam.
Continue to run the plastic opening tool down the seam.
Carefully pry around the corner with a plastic opening tool.
Pry along the top of the phone with a plastic opening tool.
Push the plastic opening tool down to free the corner of the midframe from the display assembly.
Free the clips along the power button side of the phone.
Lastly, free the two clips along the top and bottom edge of battery compartment.
Lift the display assembly out of the midframe.
crwdns2935229:052crwdne2935229:0
crwdns2947412:05crwdne2947412:0
There are two hidden clips near battery housing. One inside in upper part of battery housing and the second below battery near antenna.
milankerslager - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
How do I fix the glass
Nena Summer Perez - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Very good job you are doing. It is very helpful to us. Thanks for sharing your knowledge to the people my wishes are with you god bless you.
HARDIK PANCHOLI - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
very very very useful brother
Arunkrishna T H - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Brilliant Thanks.
michaeleggar6 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
