crwdns2959928:0crwdne2959928:0 ↓Use this guide to replace the front panel display assembly on your Samsung Galaxy Note II.
Grasp the end of the stylus and remove it from its slot in the midframe.
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
Lift the rear case by the corner nearest the divot and remove it from the phone.
If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Remove the microSD card.
Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
Remove the battery from the midframe.
Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
Slide the plastic opening tool down the seam.
Continue to run the plastic opening tool down the seam.
Carefully pry around the corner with a plastic opening tool.
Pry along the top of the phone with a plastic opening tool.
Push the plastic opening tool down to free the corner of the midframe from the display assembly.
Free the clips along the power button side of the phone.
Lastly, free the two clips along the top and bottom edge of battery compartment.
Lift the display assembly out of the midframe.
Use a spudger to disconnect the vibrator/power button assembly cable connector.
Disconnect the antenna cable connector.
Disconnect the display cable connector.
Disconnect the front-facing camera cable connector.
Disconnect the headphone jack cable connector.
Disconnect the digitizer cable connector.
Use the spudger to disconnect the antenna cable connector from the motherboard.
Disconnect the soft button cable connector.
Disconnect the USB board cable connector.
Remove the 3 mm Phillips #00 screw securing the motherboard to the display assembly.
Remove the 3 mm Phillips #00 screw securing the headphone jack assembly to the display assembly.
Grasp the headphone jack portion of the assembly and lift it out of its groove in the display assembly.
Gently pull the headphone jack straight up without twisting the cable to remove the earpiece speaker portion from its recess.
Remove the 3mm Phillips #00 screw from the front-facing camera bracket.
Remove the front-facing camera bracket.
Remove the 3 mm Phillips #00 screw securing the antenna board to the display assembly.
Insert the tip of a spudger under the antenna board to free it from the adhesive holding it to the display assembly.
Gently de-route the antenna cable from its channel in the display assembly.
Remove the antenna cable from the display assembly.
Insert the tip of a spudger under the vibrator to free it from the adhesive holding it to the display assembly.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to detach the power button from the adhesive securing it to the display assembly.
Remove the vibrator/power button assembly from the display assembly.
Remove the 3 mm Phillips #00 from the speaker enclosure.
Use the flat end of a spudger to disconnect the antenna cable connector from the USB board.
Push the flat end of a spudger under the USB board to separate it from the display assembly.
Remove the USB board from the display assembly.
Gently deroute the antenna cable from its notch in the display assembly.
Remove the antenna cable.
crwdns2935229:0183crwdne2935229:0
crwdns2947412:012crwdne2947412:0
This guide is awful. Not even the US phone model. mine and most on youtube does not have the antennae on both side, only a antena on one of the sides of the phone.
Also this does not cover how to remove most things that you HAVE to remove when you buy the digitizer+lcd from here... not to mention that it stops in the middle...
there is a video on youtube from https://www.youtube.com/user/LE55ONS that shows how to dismantle the note2 in much more detail than this... and he goes all the way and show how to remove every piece needed.
gcb - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
thx for the video!
note i was repairing looked slightly different. no antenna on the left and powerbutton/vibrator where differnet parts, midframe is hold by 2 additional tabs inside battery compartment. video was a good addition to this guid, and helped alot ;)
Lego - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thank you for the link to the videos, it helped particularly for the vibrator and power button.
anonymous 4780 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
This is the Sprint model, SPH-L900. It's not his fault that your phone is different.
Roger - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
This guide showed me how to take mine apart in ten minutes every step was included in this guide...dont know what phone you have^^^^but this is a great guide
chad - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
