If your device isn’t properly taking photos and video, the camera may be faulty. Use this guide to replace the front camera in your device.
Place your device face down on a clean surface.
Use a Spudger to remove the back cover using the notch at the top left.
Use a Spudger to remove the battery using the notch located underneath the battery.
Note: During the creation of this guide, we did not have access to a battery.
Use a Philips #000 Screwdriver to remove the fifteen 4mm screws.
Use a Spudger to remove the black chassis and expose the motherboard.
Use a Spudger to separate the camera's connector.
Use a Spudger to remove the camera from its slot.
