Samsung Galaxy Note Edge Display Assembly Replacement
crwdns2936621:0crwdne2936621:0
  1. Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Switch off the device.
    • Remove the back cover and the battery.
  2. Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Rear Housing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Rear Housing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Rear Housing: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the Memory card, the SIM card and the S Pen.
    • Remove the screws by using Screwdriver Phillips #00
    • With a plastic opening tool emove the Back Frame.
  3. Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Motherboard 1: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Motherboard 1: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Motherboard 1: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect one by one:
    • Coaxial antenna cable (x2)
    • Home Button flex cable
    • Display Flex cable
    • Stylus Sensor flex cable
    • Front Camera flex cable
  4. Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Motherboard 2: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Motherboard 2: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Motherboard 2: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry up the connector on the back of the board to release the bottom part of motherboard.
    • Gently remove the logic board.
  5. Samsung Galaxy Note Edge Display Assembly Replacement, Test the new spare part: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note Edge Display Assembly Replacement, Test the new spare part: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note Edge Display Assembly Replacement, Test the new spare part: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • I prefer to test the new spare part before install it.
    • Transfer the Power button / Loud speaker flex cable.
    • Install the mother board.
    • Test the display.
    • To prevent damage to the put back the back frame before the test.
  6. Samsung Galaxy Note Edge Display Assembly Replacement, Check the Thermal Pads: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Check the quality of the thermal pads (if the spare part is not original).
    • If its necessary use the thermal pads from the old assembly.
  7. Samsung Galaxy Note Edge Display Assembly Replacement, Transfer all the parts from the old Display assembly - Part 1: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note Edge Display Assembly Replacement, Transfer all the parts from the old Display assembly - Part 1: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note Edge Display Assembly Replacement, Transfer all the parts from the old Display assembly - Part 1: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert wisdom here.
  8. Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Charging Port Flex Assembly.: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Charging Port Flex Assembly.: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Charging Port Flex Assembly.: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the black Phillips screw,
    • the the charging port plate,
    • disconnect the Home buttons flex cable
    • and the coaxial antenna cable (x2).
    • Use hot air and a plastic opening tool to remove the Charging Port flex assembly.
  9. Samsung Galaxy Note Edge Display Assembly Replacement, Reassembling: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To reassemble your device, follow these instructions in reverse order.
ZFix
crwdns2935283:012/09/13crwdne2935283:0
195,943 crwdns2915208:0crwdne2915208:0
crwdns2935297:0330crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0329crwdne2931471:0
crwdns2935297:01,452crwdne2935297:0
crwdns2942667:0crwdne2942667:0 2,395
