Samsung Galaxy Note 8.0 Battery Replacement
  1. Samsung Galaxy Note 8.0 Battery Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Samsung S-Pen stylus.
    • Remove the micro SD storage card.
  2. Samsung Galaxy Note 8.0 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opening tool, start where the S-pen was located and carefully pry up the corner.
  3. Samsung Galaxy Note 8.0 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Work your way around the entire device by carefully prying and sliding the plastic opening tool.
    • There are clips approximately 2cm apart. As you are removing the back cover you should hear the clips being dislocated from the tablet.
    Nicht nur die Micro SD Karte… auch die SIM Karte sollte entfernt werden.
    Klaus Hummel - crwdns2934203:0crwdne2934203:0
  4. Samsung Galaxy Note 8.0 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note 8.0 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 8 Phillips#00 3-mm screws holding the battery in place.
    The photo highlighting the screws is incorrect, the highlight in the upper right side is a plastic tab, whereas the actual 8th screw to remove is on the bottom (but that's fairly easy to identify when performing the fix).
    fortyseveneffects - crwdns2934203:0crwdne2934203:0
    Can’t loosen screws on battery
    Mary - crwdns2934203:0crwdne2934203:0
  5. Samsung Galaxy Note 8.0 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the top left corner of the battery up by the black tab.
  6. Samsung Galaxy Note 8.0 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently grasp and lift up the white connector located at the bottom right corner of the battery. It is connected to the battery by two blue and two red wires.
    • Do not yank the connector by the wires. If it does not disconnect easily, slide a plastic opening tool between the white connector and the board to lift the connector away from the board.
    the white battery connectory also has 2 black wires, so 2 blue/2red/2black
    suziquirke - crwdns2934203:0crwdne2934203:0
    There is some sort of safe unit in the upper left corner. It is a connector that opens when you lift off the backside. The safe was not in properly fit when I closed the back. In fact, the most difficult step was to get the safe unit properly in place while closing the backside.
    henriknaslund - crwdns2934203:0crwdne2934203:0
    Thanks @henriknaslund for note on the "Safe Unit" I succesfully managed to hold it in pace with a little basic sticky tape. Did the job.
    derek - crwdns2934203:0crwdne2934203:0
    Piece of cake. Entire procedure took just 15 minutes. Thank you, Joel & Co., for making this so easy!
    Flipped Gazelle - crwdns2934203:0crwdne2934203:0
    why is this under galaxy note 8? the note 8 is not a tablet??? Please respond to my comment as I will check back. I need to fix my NOTE 8 POWER BUTTON…does not work properly. Makes a “short” sound…as in electrical.
    HELP!!
    Barbara Lamb - crwdns2934203:0crwdne2934203:0
    The Galaxy Note 8 was the designation for the 8 inch WiFi tablet long before Samsung confused everyone with the Note 8 phone. When Im looking for items for the tablet I usually only get things for the phone.
    J E De Armond - crwdns2934203:0crwdne2934203:0
    When the Galaxy Note 8 Battery is replaced is all data, contact info,
    downloads, photos etc lost ??
    Allan PRING-SHAMBLER - crwdns2934203:0crwdne2934203:0
crwdns2935229:085crwdne2935229:0
Joel
crwdns2935283:009/23/14crwdne2935283:0
1,868 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 12-2, Blackwell Fall 2014 crwdns2935289:0USF Tampa, Team 12-2, Blackwell Fall 2014crwdne2935289:0
USFT-BLACKWELL-F14S12G2
crwdns2947412:014crwdne2947412:0
Please help on the connector wire connections coz mine snapped and i dont know which which is supposed to be in place.. Will be waiting.. Thanks..
Narz Ferrariz - crwdns2934203:0crwdne2934203:0
Even me, 65 blond, woman made it thanks to your good guide. Thank you!!
elisabethbengzon - crwdns2934203:0crwdne2934203:0
This was a great help! I was able to replace my son's battery in 10 mins. I purchased the battery from eBay for only $8. Saved me a lot of money.
orchidsinjune0511 - crwdns2934203:0crwdne2934203:0
My Note would not turn on at all even though it was fully charged. Did not think it was on/off button so I followed the instructions for the Bios (reboot). Thought about it and had a program that was being fussy about turning off maybe causing an overload. These are very easy instructions to follow and better yet, it worked! My Note turned on and all is good with my world again. Learned that I really need to back up everything I have on my note. I reviewed all the instructions for the replacing of various parts and have to say the parts prices are more than reasonable. Thank you very much for having these instructions available to us novices.
Marcia Strickland - crwdns2934203:0crwdne2934203:0
I just wanna say thanks, the instructions were easy to follow. I'm left-handed so I had to turn my tablet in opposite directions to get the job done. I was very nervous messing with computer parts. Thanks again.
patricia Gibson - crwdns2934203:0crwdne2934203:0
Do you have to buy the plastic opening tool or does it come with the tablet? I don't believe I have one. Can I use something else?
JoAnn Romischer - crwdns2934203:0crwdne2934203:0
100% done and working but my wifi signal drop, i'm 7ft away from my router and i'm getting 2 bars instead of full bars,
in my room where i used to get 3-4 bars, I now get 1 to 0 bars, so what has happen?
Pernell Gardiner - crwdns2934203:0crwdne2934203:0
Wow, these instructions were great! Lucky I had a tiny enough phillips screwdriver to remove the battery screws, and a tiny flat screwdriver to substitute for the plastic opening tool. Thank you!
Bill Spikowski - crwdns2934203:0crwdne2934203:0
Don't know how this article is directed to Note 8. Not even for sale yet!
ghhilt57 - crwdns2934203:0crwdne2934203:0
You must have figured the answer to your question by now. If not, then this is for tablet Note 8. You are talking about the Note 8 phone.
Qualex Industrial Ventures -
To ghhilt57: this is for the galaxy note 8, from 2013, not the phone from 2017.
mirandaharrell1981 - crwdns2934203:0crwdne2934203:0
Question, does samsung offer a battery replacement service for their phones out of warranty like Apple does? I'm all for diy replacements and user replaceable batteries, but once my note 4 dies, and I'm forced to a sealed battery, I think it would be better to let the manufacturer replace the battery with an oem battery than a third party. From all the reviews I've read about note 4 3rd party batteries, they are terrible after a few months. So even if this was simpler to do, I still wouldn't trust any 3rd party battery manufacturer.
adobepro - crwdns2934203:0crwdne2934203:0
Excellent and helpful. Worked great!
JasonJ Brown - crwdns2934203:0crwdne2934203:0
Merci pour ce tuto très clair. Réparation terminée
michel seys - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 99,709
