Samsung Galaxy Note 3 Motherboard Replacement
  1. Samsung Galaxy Note 3 Motherboard Replacement, Remove the rear case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
  2. Samsung Galaxy Note 3 Motherboard Replacement, Remove Case from the Base: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note 3 Motherboard Replacement, Remove Case from the Base: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide your fingernail or plastic opening tool along the edge of the rear case.
    • Lift the case gently from the base.
    Why... is it not simple enough already lol
    Adam Ahmed - crwdns2934203:0crwdne2934203:0
  3. Samsung Galaxy Note 3 Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note 3 Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
    • Lift the battery out of its recess.
  4. Samsung Galaxy Note 3 Motherboard Replacement, S Pen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place your fingernail in the groove of the stylus pen.
    • Pull the stylus pen away from the phone.
  5. Samsung Galaxy Note 3 Motherboard Replacement, Unscrew Back Chassis: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the twelve 4mm Phillips #00 screws from the back chassis.
  6. Samsung Galaxy Note 3 Motherboard Replacement, Remove Back Chassis: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the plastic opening tool into the Stylus Pen placement holder.
    • Lift the plastic opening tool so that the midframe separates from the base.
  7. Samsung Galaxy Note 3 Motherboard Replacement, Screw Removal: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note 3 Motherboard Replacement, Screw Removal: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the single screw beside headphone jack.
    You can skip this step, it is usseles as this screw doesn’t attach the mother board at all
    Oriol Felisart - crwdns2934203:0crwdne2934203:0
  8. Samsung Galaxy Note 3 Motherboard Replacement, Unfasten Clips and Cable Connectors: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note 3 Motherboard Replacement, Unfasten Clips and Cable Connectors: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to remove both antenna clips.
    • Use a spudger to disconnect six cable connectors.
  9. Samsung Galaxy Note 3 Motherboard Replacement, Motherboard Removal: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull up on the motherboard with tweezers.
    Can i change at&t board to 9002 or 9005??,
    Ayyaz - crwdns2934203:0crwdne2934203:0
    My mother board is not working what should I do I can't use Bluetooth, WiFi,hotspot or insert sim
    soha Javed - crwdns2934203:0crwdne2934203:0
    My wifi hotspot is not working
    Kiran Thopate - crwdns2934203:0crwdne2934203:0
crwdns2935229:074crwdne2935229:0
Brittany Gail
crwdns2935283:009/23/14crwdne2935283:0
8,518 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-2, Blackwell Fall 2014 crwdns2935289:0USF Tampa, Team 2-2, Blackwell Fall 2014crwdne2935289:0
USFT-BLACKWELL-F14S2G2
crwdns2935297:025crwdne2935297:0
I'm looking for the screws for this phone, but all the search hits I've come across are for the screwdriver. Any leads on where I can find the screws?
Jared Lunt - crwdns2934203:0crwdne2934203:0
I can replace motherboard sm-n9005 with motherboard sm-n900
yacine - crwdns2934203:0crwdne2934203:0
I want to replace motherboard of galaxy note 3 SM-N900 with SM-N9005. Is it possible and can it convert 3g to 4G. Because my phone doesn't support 4G .it is 3g and I want to make it 4G .what should I do help me
Nippy Preet -
I am also looking for the same question
Jalil Ahmad -
crwdns2936753:030crwdne2936753:0 56
crwdns2942667:0crwdne2942667:0 51,036
