Samsung Galaxy Note 3 Display Assembly Replacement
crwdns2942287:0crwdne2942287:0This guide shows how to remove everything from the display assembly.
- Galaxy Note 3 Vibrator (Verizon/Sprint)crwdns2943225:0crwdne2943225:0crwdns2931591:0Ebaycrwdne2931591:0
crwdns2944105:0crwdne2944105:0
Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
Slide your fingernail or plastic opening tool along the edge of the rear case.
Lift the case gently from the base.
Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
Lift the battery out of its recess.
Place your fingernail in the groove of the stylus pen.
Pull the stylus pen away from the phone.
Remove the twelve 4mm Phillips #00 screws from the back chassis.
Insert the plastic opening tool into the Stylus Pen placement holder.
Lift the plastic opening tool so that the midframe separates from the base.
Remove the single screw beside headphone jack.
You can skip this step, it is usseles as this screw doesn’t attach the mother board at all
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to remove both antenna clips.
Use a spudger to disconnect six cable connectors.
Pull up on the motherboard with tweezers.
Can i change at&t board to 9002 or 9005??,
My mother board is not working what should I do I can't use Bluetooth, WiFi,hotspot or insert sim
My wifi hotspot is not working
Insert the spudger into the headphone jack.
Lift the spudger to separate the jack assembly from the motherboard.
Pull to remove.
Remove the metal bracket located in the top left hand corner.
As well as the front camera and sensor up under it.
Remove the vibrating motor by pulling up on it carefully with the tweezers.
toggle the motor on the left, cause you need to remove the start button with the motor in the same time.
All is paste on the display assembly. Use a screw to pass under the elements, and unglue them.
Lift USB port from the front assembly using the tweezers.
You need to pull up the USB port and all the blue card.
Use a screw to pass under the card, beacause everything is paste on the display assembly.
Be VERY careful with the board, or just leave it there.
In some (I think all) devices, the board is GLUED with the display assembly.
Maybe to stabilize the port (But they can use screws, right? D*mn nasty glue!).
You are now left with the display assembly.
Wonderful description.
It tooks me about an hour to change the display.
Thanks for this tutorial.
crwdns2935229:0146crwdne2935229:0
crwdns2947412:010crwdne2947412:0
είναι απόλυτα κατανοητό.
Can you just replace the digitizer or is the digitizer glue down to good to the display where it might damage the LCD display when trying to replace the digitizer?
to safely remove the LCD display from the front touch screen glass w/o damaging the LCD screen I advise you to invest in and familiarize yourself with an LCD Separator machine and all the accessories that go along with it. Also, search for the machine and watch the videos..
Can you just replace the digitizer or is the digitizer glue down to good to the display where it might damage the LCD display when trying to replace touch
This tutorial is incomplete, for instance the 'vibrator motor' removal does not specifies that this also removes the power button, and the removal of the front camera and light sensor is omitted, and the fact that heating the usb port part is very helpful if not mandatory before lifting it. I followed the video tutorial here which is complete: Samsung Galaxy Note 3 Display Assembly Video Tutorial Replacement
How do I remove the screen/digitizer/front glass from the display assembly? I have a broken screen and need to install the replacement LCD/digitizer piece I bought, and need to install it into the display assembly before reassembling.
How I can replace the wifi and bluetooth part in note?
warning :
on the new part (display assembly) don’t forget to remove plastic protection on the radiator of cpu !!
I have successfully replaced the display with a new display, at which point the power button wasn’t working properly because I didn’t install it properly - fixed that, and I have now noticed that the phone will charge with the back plate on, only, however if I screw the back plate in this stops it from charging. What am I doing wrong?
