This is the back of the device and where you willl begin to take it apart
It is necessary to remove the silver piece covering the camera first before removing the bigger back piece.
Use the plastic opening tools to pry along the indicated box.
Lift up the silver piece to reveal the rest of the back cover.
Unscrew the three screws indicated by the red circles with the Philips #00 screwdriver.
Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
Remove the back cover.
Start by lifting the white connector to remove the part indicated by the red polygon.
Gently pry along the camera hub to lift it out of its location.
This is your camera. Replace it with the new part.
