Are you not satisfied with your sound coming of your Galaxy Nexus?
This guide will help you replace ear piece part of your phone.
You must open the back of the phone to access the battery. To do this use the plastic opening tools or your fingernail and insert it into the divot.
Remove the back cover of the phone by moving the prying tool or your fingernail away from the phone while it is still in the divot.
Insert your finger into the divot of the battery and pull the battery towards yourself to remove.
This is when a new battery will be inserted.
Remove 4.4 mm screws using a PH # 000 as indicated on the picture.
After removing the screws be sure to turn the phone right side up.
Insert your plastic opening tool between the screen and the outer case. Move the opening tool around the phone without removing it from in between the screen and the shell of the phone.
Unscrew 4.4mm with a PH #000 marked screw.
With the flat head screw driver pull up the blue connector.
With you finger or prying tool pull back bottom module.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the internal battery using tweezers or your flat head screw driver.
Peel the display connector strip off the main circuit board using the tweezers.
Peel the USB connector strip off the main circuit board using the tweezers.
Remove the antenna using either your fingers or tweezers.
Using tweezers, pull the top circuit board off.
Using tweezers pull the top earpiece out.
