Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement
  1. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement, Screen & Digitizer Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before beginning, make sure the phone is turned off.
    • On the back of the phone, find the slot at the charging port located at the bottom of the phone.
    • Either insert the plastic opening tool or use your fingernail to pull up on the back cover.
    • Once the corner is released, slide your finger around the outside until the back cover releases.
  2. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the battery.
    • Insert fingernail or plastic opening tool into the slot on the bottom of the battery and gently lift up.
    • Remove the battery.
  3. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a phillips head PH000 and remove all 13, 1.4 mm visible screws.
    • Using the pry tool, carefully pop the Digitizer cover off the device.
    • Use the pry tool to disconnect the digitizer
  4. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the pry tool along the side of the device, then work your way around the borders of the screen, separating the screen from the rear assembly frame.
    • Be careful and do not lift the screen completely off yet, leave the screen at an angle.
    • Use the heat gun to heat up the bottom to loosen the adhesive from the menu and back buttons.
    • Once heated, gently pull the screen upward.
    • Make sure that the buttons are separating from the adhesive.
  5. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now, seperate the screen from the outside frame of the phone (the bezel).
Taylor Powell
crwdns2935283:009/08/17crwdne2935283:0
804 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team S1-G6, Virtue Fall 2017 crwdns2935289:0Western Carolina University, Team S1-G6, Virtue Fall 2017crwdne2935289:0
WCU-VIRTUE-F17S1G6
crwdns2942667:0crwdne2942667:0 1,492
