Samsung Galaxy J7 Screen Assembly Replacement
    1. Samsung Galaxy J7 Screen Assembly Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy J7 Screen Assembly Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Locate the Tab: Find the tab at the top left corner of the back cover. (highlighted by red square)
      • Insert the tool: Use a fingernail or a plastic opening tool to lift the tab gently
      • Pry open the cover: Carefully work around the edges to remove the back cover completely
      • If the cover is stuck do not force it open use a plastic opening tool to avoid scratching the case.
    1. Samsung Galaxy J7 Screen Assembly Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy J7 Screen Assembly Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Locate the Battery slot: Find the small slit at the bottom right corner of the battery (highlighted by red square)
      • Remove Battery: Gently pop out the edge and carefully pull out the battery.
      • Tip: Ensure the battery is disconnected from the motherboard before removing it.
    1. Samsung Galaxy J7 Screen Assembly Replacement, Midframe: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the Phillips #000 screwdriver, remove the ten 4.2 mm screws around the edge of the midframe.
    2. Samsung Galaxy J7 Screen Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy J7 Screen Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy J7 Screen Assembly Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift up the back of the device with the iFixit opening tool and disconnect it from the front.
      • If the back panel is difficult to remove, gently heat the edges using a hair dryer or heat gun to soften the adhesive.
    1. Samsung Galaxy J7 Screen Assembly Replacement, Screen Assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy J7 Screen Assembly Replacement, Screen Assembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The speaker piece is lightly adhered. Use a plastic pry tool to gently lift it up and disconnect the cable.
    2. Samsung Galaxy J7 Screen Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy J7 Screen Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently lift up the tab of the motor.
      • Remove the motor from the panel completely to disconnect it.
      • Removing the motor allows easier access to the screen assembly for replacement. Handle the motor and its connectors with care.
    3. Samsung Galaxy J7 Screen Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Reverse these steps with your new phone screen to replace it.
      • After reassembly, test the new screen for touch responsiveness and display quality before fully securing the device
crwdns2935229:016crwdne2935229:0
Gabriel Arellano
crwdns2935283:002/05/19crwdne2935283:0
513 crwdns2915208:0crwdne2915208:0
Appalachian State University, Team S2-G5, Menagarishvili Spring 2019 crwdns2935289:0Appalachian State University, Team S2-G5, Menagarishvili Spring 2019crwdne2935289:0
APSU-MENAGARISHVILI-S19S2G5
crwdns2935297:084crwdne2935297:0
I replaced the broken screen....before I saw this. Now my phone will not turn on. what should I do? ruth.fnp@gmail.com
Ruth Thomas - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 35
crwdns2936753:030crwdne2936753:0 103
crwdns2942667:0crwdne2942667:0 13,121
