This guide will walk you through the process of replacing a not working back camera in a Samsung Galaxy J3V.
Place your thumb on the top left corner and pry the tab open and lift off the back cover.
Remove the ten 2.0 mm screws with the Phillips #J000 screwdriver.
Use a small suction cup to pull the screen up. Then slip a small plastic opening tool under the screen to pry it upwards.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to flip tab of the front camera to remove it.
Remove connector tab with spudger then carefully remove headphone jack with tweezers.
Remove these connectors from the motherboard with spudger.
Carefully use the spudger to pry the motherboard out of the plastic tabs.
After removing the motherboard, locate and flip tab holding the rear camera's connector.
Carefully use the tweezer to remove the connector and the camera.
Your &&^&^$^ trash and did not help me at all.
Harrington Kenneth - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
