Samsung Galaxy J3 Home Key Replacement
Nicole Gooch
crwdns2944107:0crwdnd2944107:0Nicole Goochcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:06crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Sun 9, 2025crwdne2944111:0
crwdns2931287:015crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
If the home button on your Samsung Galaxy J3 phone is sticking or no longer working, you may need to remove and replace it.
Sometimes, problems with the home button can be solved without needing to remove the button entirely. The troubleshooting page for the Samsung Galaxy J3 offers solutions to common issues with the phone. If you determine that you will need to remove and replace the home button, follow the steps of this guide.
Before you begin, make sure your phone is disconnected from any external power source and is powered off completely.
  1. Samsung Galaxy J3 Home Key Replacement, Home Key: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the back casing from the phone by carefully using your fingers to pry them apart.
  2. Samsung Galaxy J3 Home Key Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery.
  3. Samsung Galaxy J3 Home Key Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all ten screws by using a Phillips #000 screwdriver.
  4. Samsung Galaxy J3 Home Key Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat side of a spudger to remove the middle frame bezel.
    • Do not twist or wrench the spudger during this step as it will cause the screen to crack.
  5. Samsung Galaxy J3 Home Key Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the glass up from the side of the phone and push the home button out.
    • When you pull the glass up, it will make a popping sound. This is normal.
  6. Samsung Galaxy J3 Home Key Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the home button and press the glass back in place.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Nicole Gooch
crwdns2935283:009/20/17crwdne2935283:0
207 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S7-G2, Thomas Fall 2017 crwdns2935289:0University of North Texas, Team S7-G2, Thomas Fall 2017crwdne2935289:0
UNT-THOMAS-F17S7G2
NEVER NEVER do this!!!! In the last picture I can see the LCD broken apart!!! You may never open an J3 like this, because the LCD screen will brake and this is what happen in the last 2 pictures, this man separated the screen in 2 parts and now the screen does not work. Check some videos in youtube and you will know what I am saying.
Leonardo Sierra - crwdns2934203:0crwdne2934203:0
you see, you clearly know nothing about phones, because the last picture shows nothing resembling a broken lcd. however, there is a much simpler way of doing this and he did take an over-complicated approach. sidenote: if you use youtube for your information instead of guides by professionals, you have some issues.
Blins Cat -
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 3,100
