Use this guide to replace your motherboard. When following these steps ensure that you do not remove the glass screen from the digitizer during step four.
Insert a finger nail or plastic opening tool between the back cover and the device.
Gently pry the rear cover off of the back of the phone.
Using a finger, pull the SIM card down out of its slot.
Remove the SIM card.
Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
Insert a plastic opening tool between the screen and the back of the device.
Starting at the bottom of the device, gently slide the tool along the edges of the screen.
Gently pry the main assembly from the midframe of the device.
Use the flat edge of a spudger to disconnect the ear speaker connector.
Use the flat end of a spudger disconnect the digitizer connector.
Use the flat end of a spudger disconnect the front-facing camera cable connector.
Use the flat end of a spudger to gently pry under the motherboard.
Remove the motherboard.
Use the flat end of a spudger to disconnect the rear camera cable connector.
crwdns2935229:024crwdne2935229:0
can you plz give use a amazon link to part
Very good illustration..where can I get a motherboard?
Where can I get a motherboard for this phone Samsung J100?
I need the details of the motherboard
