Samsung Galaxy Grand Prime Digitizer and LCD Replacement
  1. Samsung Galaxy Grand Prime Digitizer and LCD Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Grand Prime Digitizer and LCD Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Grand Prime Digitizer and LCD Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Digitizer and LCD Replacement, Remove the battery.: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Grand Prime Digitizer and LCD Replacement, Remove the battery.: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Grand Prime Digitizer and LCD Replacement, Remove the battery.: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Prime Digitizer and LCD Replacement, Midframe: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Grand Prime Digitizer and LCD Replacement, Midframe: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Grand Prime Digitizer and LCD Replacement, Midframe: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Prime Digitizer and LCD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Grand Prime Digitizer and LCD Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Prime Digitizer and LCD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Grand Prime Digitizer and LCD Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure that you detach the mid-frame from the inside too.
  6. Samsung Galaxy Grand Prime Digitizer and LCD Replacement, Digitizer and LCD: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect all flex cables and remove the motherboard and the front-facing camera.
    • The display assembly is attached to the frame with adhesive.
    • Insert an opening pick between the glass and the frame in the gap above the front-facing camera bracket. Begin to slice through the adhesive on the top bezel of the phone.
  7. Samsung Galaxy Grand Prime Digitizer and LCD Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Grand Prime Digitizer and LCD Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the right corner, gently twist the pick up and down to further separate the adhesive, then insert it as shown between the LCD and the frame.
    • Insert a second pick into the gap between the frame and the display flex cable.
    • Move both picks towards the bottom of the phone to separate the adhesive on the sides of the screen.
  8. Samsung Galaxy Grand Prime Digitizer and LCD Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply heat to the bottom bezel, then insert a pick between the frame and the digitizer.
    • To avoid damaging the home button, ensure the pick goes above it as shown.
    • The home button may fall out.
  9. Samsung Galaxy Grand Prime Digitizer and LCD Replacement, Removing the screen assembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the adhesive on the bottom half of the phone, flip it around, and separate the frame from the screen assembly starting from the bottom.
    • Ensure the display cable can freely move through the hole in the frame.
    • The ear speaker grille may fall out.
  10. Samsung Galaxy Grand Prime Digitizer and LCD Replacement, Separating the LCD and digitizer: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Grand Prime Digitizer and LCD Replacement, Separating the LCD and digitizer: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The LCD and digitizer are not glued together with LOCA glue, but just with adhesive around the edges of the digitizer.
    • The digitizer is connected to the LCD with a flex cable. Flip up the bottom half of the connector.
    • Apply gentle heat to the IC. Insert a pick as shown and separate.
    • To separate the LCD and digitizer, apply gentle heat to the front of the assembly and gently slide picks along the edges of the LCD.
Patrick
crwdns2935283:005/14/14crwdne2935283:0
6.734 crwdns2915208:0crwdne2915208:0
crwdns2935297:021crwdne2935297:0
crwdns2936753:030crwdne2936753:0 45
crwdns2942667:0crwdne2942667:0 2,179
