Don't panic if the back or recent tabs button stops working; just follow this relatively simple guide to replace them. You will need to remove the screen.
Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
Once the cover is removed, locate the battery that reads "SAMSUNG."
Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
Use a Plastic Prying Tool (such as a spudger) to pop out piece shown.
Use a blow dryer or heating pad to heat up the screen.
Use a Thin Plastic Tool (such as a guitar pick) or Plastic Prying Tool (such as a spudger) to lift out the glass digitizer and LCD screen around the edges.
Use a plastic tool to remove back and/or recent tabs circuit buttons.
