A common problem you may have with the Samsung Galaxy Core Prime is a sticky or broken home button. Rather than go somewhere to fix it you can use this guide to help you remove or readjust the button. You will need tweezers, a heat gun or hair dryer, a Phillips #00 screwdriver, and an iFixit Opening Tool.
Turn the smartphone off by using the power button on the right-hand side.
Turn the smartphone over so that the rear camera is face up.
Use your fingernail or a flat tool to lift the back cover.
Locate the battery near the bottom of the phone. The battery is square, flat, and is labeled 'SAMSUNG'.
Use your fingernail or a flat tool to lift the battery out.
Use your thumb to remove the sim card.
Use a Phillips #00 screwdriver to remove the eight 4 mm screws that secure the midframe.
Heat the frame with a hair dryer or heat gun. Do this until the adhesive is loosened.
crwdns2935267:0crwdne2935267:0iFixit Opening Tool$1.99
Use a flat tool or the iFixit Opening Tool to lift the midframe.
Disconnect the LCD screen/touch screen ribbon from the motherboard using tweezers.
Lift the motherboard out using the iFixit Opening Tool.
Heat the sides of the screen with a heat gun or hair dryer.
Use the iFixit Opening Tool to remove the plastic panel that separates the motherboard and the screen.
Use tweezers to remove the home button.
