Begin removing the 3/16" screws for the device.
Turn the device and remove the additional 3/16" screws.
Turn the device and remove the additional 3/16" screw.
Using the plastic opening tools, pry open the camera from the bottom.
Gently pull the connector away from the motherboard.
Unscrew the motherboard's screws. There are 4 3/32" screws and 3 5/32" screws.
Unscrew the lens' screws. There are 1 black 4/32" screw, 3 3/16" black screws, and 2 white 5/32" screws.
Pull these connectors away from motherboard.
Lift the motherboard and lens out of the case.
Remove all the screws circled. There is 1 1/8" screw by the flash, 1 9/32" screw that holds the flash button, 2 5/32" screw that is on the grey frame for the flash, and 2 5/32" screws that holds the cable frames on the top left.
Unscrew the 3 5/32" screws that cover the battery plate.
The black plates on the other side can be removed after these screws.
Pull the flash and battery case out of the device.
crwdns2935229:013crwdne2935229:0
