Begin by turn the device over to it's back, with the screen facing down.
At the top of the device there is a small notch that is used to remove the battery door.
Using a pry tool or your fingernail, pry off the battery door from the main housing.
Place the battery door to the side.
Using a pry tool or your fingernail, pry the battery up towards you.
You have now removed the battery!
Remove the 6 Phillips head screws that hold the rear housing in place.
Using a spudger or plastic pry tool, slowly go around the phone between the display & rear housing to release the clips.
Lift the rear housing from the display assembly.
Using your spudger/plastic pry tool, disconnect the headphone jack flex cable.
Using your spudger/plastic pry tool, disconnect the rear speaker flex cable.
Using a spudger/pry tool, carefully remove the vibration motor from its housing. This has a mild adhesive on the bottom.
After removing both flex cables, slowly move the logic board to the left of the screen assembly.
Using your spudger/plastic pry tool, disconnect the LCD/Digitizer flex cable.
You have now removed the logic board from the display assembly.
Using a spudger/plastic pry tool lift the brown ZIF tab on the front-facing camera connector.
Carefully pull the camera out of it's connector and set to the side.
