Samsung Galaxy Alpha Battery Replacement
  1. Samsung Galaxy Alpha Battery Replacement, Removing the Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Alpha Battery Replacement, Removing the Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Alpha Battery Replacement, Removing the Back Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On the back panel of the phone, find the slot that is on the top left side next to the flashlight.
    • Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel.
    • Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
  2. Samsung Galaxy Alpha Battery Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Alpha Battery Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure the device is powered down before moving forward.
    • Since the NFC antenna is glued to the battery, make sure the replacement also includes one.
    • Locate the slot at the base of the battery and insert your thumb.
    • Push slightly toward the battery and out, away from the phone to free the battery.
crwdns2935229:011crwdne2935229:0
Jon Brausch
crwdns2935283:001/20/15crwdne2935283:0
1 572 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 20-17, Maness Winter 2015 crwdns2935289:0Cal Poly, Team 20-17, Maness Winter 2015crwdne2935289:0
CPSU-MANESS-W15S20G17
Not even a full picture of the battery agh! I need to know if I can use note 4 battery
Alex Andrei - crwdns2934203:0crwdne2934203:0
Please also make sure that replacing the battery with a cheap knock off will disable NFC since the antenna is glued to the battery.
vargabp0 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,237
