Samsung Galaxy A70 Midframe Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Samsung Galaxy A70 Midframe Replacement, Eject the SIM tray: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A70 Midframe Replacement, Eject the SIM tray: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A70 Midframe Replacement, Eject the SIM tray: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a SIM card eject tool, a SIM eject bit, or a straightened paper clip into the hole on the SIM tray located at the left edge of the phone.
    • Press firmly to eject the tray and remove it.
  2. Samsung Galaxy A70 Midframe Replacement, Soften the adhesive: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Switch off your Galaxy A70.
    • Heat an iOpener and use it to soften the adhesive beneath the back cover. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
  3. Samsung Galaxy A70 Midframe Replacement, Create a gap: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A70 Midframe Replacement, Create a gap: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a suction cup to the back of the phone, as close as possible to the center of the right edge.
    • Pull on the suction cup to create a gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  4. Samsung Galaxy A70 Midframe Replacement, Slice the adhesive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A70 Midframe Replacement, Slice the adhesive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A70 Midframe Replacement, Slice the adhesive: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick along the edge to the bottom right corner.
    • Leave the opening pick in its place to prevent the adhesive from resealing.
    • Once you have inserted an opening pick, feel free to remove the suction cup or continue to use it for a better grip during the removal procedure.
  5. Samsung Galaxy A70 Midframe Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A70 Midframe Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A70 Midframe Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a second opening pick underneath the bottom right corner of the back cover.
    • Slide the opening pick along the edge to the top right corner.
    • If you have trouble with cutting, you can use the iOpener again to soften the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  6. Samsung Galaxy A70 Midframe Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A70 Midframe Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a third opening pick underneath the top right corner of the back cover.
    • Slide the tip of the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  7. Samsung Galaxy A70 Midframe Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A70 Midframe Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A70 Midframe Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a fourth opening pick underneath the top left corner.
    • Slide the opening pick along the left edge of your phone to cut the adhesive.
  8. Samsung Galaxy A70 Midframe Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A70 Midframe Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a fifth opening pick underneath the bottom left corner.
    • Slide it along the the bottom edge to cut the remaining adhesive.
  9. Samsung Galaxy A70 Midframe Replacement, Remove the back cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover.
    • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond — a stack of heavy books works well.
  10. Samsung Galaxy A70 Midframe Replacement, Unscrew the midframe: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the fourteen 4.0 mm-long screws that secure the midframe.
  11. Samsung Galaxy A70 Midframe Replacement, Insert an opening pick: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A70 Midframe Replacement, Insert an opening pick: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The midframe is held in place by plastic clips.
    • Insert an opening pick between the midframe and front panel assembly on the right edge of the phone near the volume button.
  12. Samsung Galaxy A70 Midframe Replacement, Detach the plastic clips: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A70 Midframe Replacement, Detach the plastic clips: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick to the bottom right corner to detach the plastic clips.
  13. Samsung Galaxy A70 Midframe Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A70 Midframe Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A70 Midframe Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue sliding the opening around the bottom right corner to the bottom left corner to detach the plastic clips.
  14. Samsung Galaxy A70 Midframe Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A70 Midframe Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A70 Midframe Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick along the left edge to detach the plastic clips.
  15. Samsung Galaxy A70 Midframe Replacement, Remove the midframe: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the midframe.
Adriana Zwink
crwdns2935283:012/18/19crwdne2935283:0
59,064 crwdns2915208:0crwdne2915208:0
crwdns2935297:0167crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:022,014crwdne2935297:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 78
