Samsung Galaxy A51 - how to disassemble the device and change broken screen
crwdns2936621:0crwdne2936621:0
Samsung Galaxy A51 - the new spare part.
Warm up the device to soften the adhesive.
Use suction cup and plastic tools (playing cards) to separate the back cover.
Remove the SIM Tray.
Remove 13x Phillips screws.
Only use plastic tools to separate the metal frame.
Test the new spare part.
Disconnect and remove the main flex cable.
To remove the fingerprint sensor - remove two Philips screws and disconnect the flex cable.
Disconnect coaxial antenna cable.
Remove the Sub -board? Charging board.
The motherboard is secured by one small black screw, remove it to separate the board.
Don't forget to transfer the receiver.
crwdns2935229:017crwdne2935229:0
Hallo, i made repleacment, display went well ( touch and functions, but after turning on the display was like in shadow and side lines were on white kind a yellow fade, what it could be? is it by bad replacement, display or something else?
