Use this guide to remove the back cover on your Samsung Galaxy A51.
You’ll need replacement adhesive to reattach the back cover when reassembling the device.
Prepare an iOpener and apply it to the back cover to soften the adhesive.
Insert the tip of an opening pick between the frame and the back cover at the bottom of the phone near the USB-C port.
If you can't get between the back cover and midframe with your opening pick, you can use a suction handle or strong tape to pull up the back cover to create a gap.
Slide the opening pick to the bottom right corner and leave it there.
Insert a second opening pick and slide it from the bottom right corner to the bottom left corner to cut the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Insert a third opening pick under the bottom left corner of the back cover.
Slide the opening pick along the left edge of the phone.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Insert a fourth opening pick under the top left corner of the back cover near the camera.
Slide the tip of the opening pick along the top edge of the phone to the right corner to cut the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
With opening picks in all four corners, insert a fifth and final opening pick under the top right corner of the back cover.
Slide the tip of the opening pick along the right edge of the phone to the bottom right corner to cut the remaining adhesive.
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
crwdns2935229:023crwdne2935229:0
