Samsung Galaxy A51 Back Cover Replacement
    1. Samsung Galaxy A51 Back Cover Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Before beginning this procedure, completely power off your phone.
      • Prepare an iOpener and apply it to the back cover to soften the adhesive.
      • The adhesive of the Samsung Galaxy A51 is very strong. You can use a hair dryer or a heat gun if you aren't able to open the device with the iOpener.
      • Be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
    2. Samsung Galaxy A51 Back Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A51 Back Cover Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A51 Back Cover Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the tip of an opening pick between the frame and the back cover at the bottom of the phone near the USB-C port.
      • If you can't get between the back cover and midframe with your opening pick, you can use a suction handle or strong tape to pull up the back cover to create a gap.
      • Slide the opening pick to the bottom right corner and leave it there.
    3. Samsung Galaxy A51 Back Cover Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A51 Back Cover Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A51 Back Cover Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert a second opening pick and slide it from the bottom right corner to the bottom left corner to cut the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
    4. Samsung Galaxy A51 Back Cover Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A51 Back Cover Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A51 Back Cover Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert a third opening pick under the bottom left corner of the back cover.
      • If you have any trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Slide the opening pick along the left edge of the phone.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    5. Samsung Galaxy A51 Back Cover Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A51 Back Cover Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A51 Back Cover Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert a fourth opening pick under the top left corner of the back cover near the camera.
      • Slide the tip of the opening pick along the top edge of the phone to the right corner to cut the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    6. Samsung Galaxy A51 Back Cover Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A51 Back Cover Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A51 Back Cover Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • With opening picks in all four corners, insert a fifth and final opening pick under the top right corner of the back cover.
      • Slide the tip of the opening pick along the right edge of the phone to the bottom right corner to cut the remaining adhesive.
    7. Samsung Galaxy A51 Back Cover Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the back cover.
      • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
crwdns2935229:026crwdne2935229:0
Adriana Zwink
crwdns2935283:012/18/19crwdne2935283:0
68,891 crwdns2915208:0crwdne2915208:0
crwdns2935297:0167crwdne2935297:0
Staff
crwdns2935297:072,303crwdne2935297:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 53
crwdns2936753:030crwdne2936753:0 200
crwdns2942667:0crwdne2942667:0 23,947
