Samsung Galaxy A41 Display Replacement
    • Found this video on how to do the repair. Worked perfectly.
  1. crwdns2935267:0crwdne2935267:0
    Anti-Static Wrist Strap
    $7.95
    • Prepare the necessary repair materials. Make sure you have everything before you start.
    • Make sure you are working with the right model. In this case, it is a Samsung Galaxy A41 (SM-A415F), in white.
    • In this video, the screen was damaged by a blow to the left side. This requires a complete display replacement.
    • You need a new replacement display for your Samsung Galaxy A41. If you want the same display quality again, you need to make sure that it is a Super AMOLED display.
  2. crwdns2935267:0crwdne2935267:0
    Heat Gun
    $24.99
    • Clean the surface and remove any adhesive residue to ensure that the new screen is clean and flush.
    • Carefully position the new display so that you can reconnect all the cables.
    • Turn on the device and check if the new display is working correctly.
Congratulations! You've done it and successfully replaced the display on your Samsung Galaxy A41.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
riiedl95
crwdns2935283:008/25/21crwdne2935283:0
143 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 119
crwdns2942667:0crwdne2942667:0 4,449
