This guide was made in the hopes of being able to help repair Samsung galaxy a12.
Remove sim tray first
Pop off the plastic back
Disconnect the lock button flex
The back cover was a little tricky, I found the top left was the part of the case that I got to open first, then you can run a plastic tool around all the sides.
I don't receive text messages, but I can text messages normally
Take the screws out
They're all the same size
Remove plastic covers
Unclip flex cables, starting with smaller
Unwind grounding screw
Disconnect antenna
Pop off the main board from Sim tray slot with spudger
Pop the flex off
Lift board with ease, kindly minding the adhesive
Put flex cable out of the way
Credit-card size plastic tool
Wedge between the side of the battery down to the corner and apply isopropyl alcohol
Tilt camera end up to avoid leaking into battery
Pry up the battery being careful to not damage it
Wow, that was a mission! I didn't have any isopropyl alcohol which i'm assuming makes it much harder. Make sure you have that before starting I guess. I used a hairdryer to heat the front of the screen, but even then it was a long job. It is properly glued in there!! Just take your time. I had a flexible piece of plastic which I managed to eventually get under the battery and just slowly worked round underneath to free it up, whilst pulling on top of the battery with a suction cup. Good luck!!!
muchisimas gracias!! muy útil y bien explicada!!
My A12 has network problem pls me.
My Samsung A12 has network problem pls in need help to fix it.
I accidentally puncture my battery please help
crwdns2935229:070crwdne2935229:0
crwdns2947412:07crwdne2947412:0
The volume of my phone is down when receiving a call
Thanks for this. Phone successfully fixed! Just an additional note for people, I noticed my replacement part was missing a lot of the grey gaskets. There are a few of these under both boards, a few small square ones, and a very thin windy one under the bottom board. Not sure if required but I transferred these across to my new one using some tweezers to very carefully peel them off. Make sure you get the "glue" bit underneath to come up at the same time if you can, otherwise you may need extra glue to reattach them. Be careful transferring the volume buttons too, they need to be carefully taken off in the same way and reattached to the new one.
How can i reset my PIN that I had forgotten without a hard reset on my A12?
يمكن تخطى القفل باستخدام اللابتوب
moga2 -
Very good thing you are doing here Big up's
👉 Perfecta la esplicación....Thank 👈
My mubail heng ho raha he
ce n'est pas collé mais vaut mieux chauffer le plastique (sèche cheveux) pour retirer le couvercle surtout les coins...
Jose Goncalves - crwdns2934203:0crwdne2934203:0
