Samsung Galaxy A12 Disassembly
  1. Samsung Galaxy A12 Disassembly, Samsung Galaxy A12 Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove sim tray first
    ce n'est pas collé mais vaut mieux chauffer le plastique (sèche cheveux) pour retirer le couvercle surtout les coins...
    Jose Goncalves - crwdns2934203:0crwdne2934203:0
  2. Samsung Galaxy A12 Disassembly, Take off the back: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A12 Disassembly, Take off the back: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pop off the plastic back
    • Disconnect the lock button flex
    The back cover was a little tricky, I found the top left was the part of the case that I got to open first, then you can run a plastic tool around all the sides.
    KevinG - crwdns2934203:0crwdne2934203:0
    I don't receive text messages, but I can text messages normally
    Mading - crwdns2934203:0crwdne2934203:0
  3. Samsung Galaxy A12 Disassembly, Unscrew the plastic covers: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A12 Disassembly, Unscrew the plastic covers: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take the screws out
    • They're all the same size
  4. Samsung Galaxy A12 Disassembly, Remove plastic covers: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove plastic covers
  5. Samsung Galaxy A12 Disassembly, Detaching main board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A12 Disassembly, Detaching main board: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A12 Disassembly, Detaching main board: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip flex cables, starting with smaller
    • Unwind grounding screw
    • Disconnect antenna
    • Pop off the main board from Sim tray slot with spudger
    تاچ و ال سی دی چطور عوض کنم؟
    مهدی نوری - crwdns2934203:0crwdne2934203:0
  6. Samsung Galaxy A12 Disassembly, Detach sub board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pop the flex off
    • Lift board with ease, kindly minding the adhesive
  7. Samsung Galaxy A12 Disassembly, Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A12 Disassembly, Battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A12 Disassembly, Battery: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Put flex cable out of the way
    • Credit-card size plastic tool
    • Wedge between the side of the battery down to the corner and apply isopropyl alcohol
    • Tilt camera end up to avoid leaking into battery
    • Pry up the battery being careful to not damage it
    Wow, that was a mission! I didn't have any isopropyl alcohol which i'm assuming makes it much harder. Make sure you have that before starting I guess. I used a hairdryer to heat the front of the screen, but even then it was a long job. It is properly glued in there!! Just take your time. I had a flexible piece of plastic which I managed to eventually get under the battery and just slowly worked round underneath to free it up, whilst pulling on top of the battery with a suction cup. Good luck!!!
    muchisimas gracias!! muy útil y bien explicada!!
    Augusto Tolozano - crwdns2934203:0crwdne2934203:0
    My Samsung A12 has network problem pls in need help to fix it.
    Santrogan Abass Bundu - crwdns2934203:0crwdne2934203:0
    I accidentally puncture my battery please help
    George Gallacher - crwdns2934203:0crwdne2934203:0
crwdns2935229:070crwdne2935229:0
Ulric
crwdns2935283:010/20/22crwdne2935283:0
2.195 crwdns2915208:0crwdne2915208:0
crwdns2947412:07crwdne2947412:0
The volume of my phone is down when receiving a call
zani gift shabangu - crwdns2934203:0crwdne2934203:0
Thanks for this. Phone successfully fixed! Just an additional note for people, I noticed my replacement part was missing a lot of the grey gaskets. There are a few of these under both boards, a few small square ones, and a very thin windy one under the bottom board. Not sure if required but I transferred these across to my new one using some tweezers to very carefully peel them off. Make sure you get the "glue" bit underneath to come up at the same time if you can, otherwise you may need extra glue to reattach them. Be careful transferring the volume buttons too, they need to be carefully taken off in the same way and reattached to the new one.
How can i reset my PIN that I had forgotten without a hard reset on my A12?
Rudaina Mustafa - crwdns2934203:0crwdne2934203:0
يمكن تخطى القفل باستخدام اللابتوب
moga2 -
Very good thing you are doing here Big up's
Charles Aboraa - crwdns2934203:0crwdne2934203:0
👉 Perfecta la esplicación....Thank 👈
Duniel Gonzalez - crwdns2934203:0crwdne2934203:0
My mubail heng ho raha he
Anroid - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 27
crwdns2936753:07crwdne2936753:0 207
crwdns2936753:030crwdne2936753:0 846
crwdns2942667:0crwdne2942667:0 35,651
