Samsung Galaxy A11 Display Assembly Replacement
  1. Samsung Galaxy A11 Display Assembly Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement, Back Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the SIM eject tool in the hole of the sim tray.
    • Push until part of the SIM tray is pushed out.
    • Pull out the rest of the SIM tray.
  2. Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pry open the area of the back cover near the SIM tray using an iFixit opening pick.
    • Gently move the pick along the gap and pry open the clips holding it together.
    • If possible, use multiple picks to prevent the back cover from closing.
  3. Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a hair dryer on low heat, heat the fingerprint sensor in increments of 30 seconds to loosen the surrounding adhesive.
    • Gently push the fingerprint sensor until it detaches from the back cover.
    • If needed, remove the button by prying it from the bottom of the device.
  4. Samsung Galaxy A11 Display Assembly Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement, Battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 3 mm screws from the shield using a Phillips #000 screwdriver.
    • Remove the shield from the phone.
  5. Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using tweezers, a spudger, or your fingers, disconnect the battery press connector from the phone.
  6. Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If needed, use a hairdryer on low heat to soften the adhesive under the battery.
    • Use an iFixit pry tool to dig under the battery edge.
    • If needed, use multiple pry tools to hold the battery in place.
    • Continue to cut the adhesive under the battery until you are able to pry the battery away from the phone.
    • Remove the battery from the phone.
  7. Samsung Galaxy A11 Display Assembly Replacement, Earpiece Speaker: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement, Earpiece Speaker: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement, Earpiece Speaker: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently use tweezers to peel up the copper strip on the top right of the phone.
  8. Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three black 3 mm screws from the speaker cover using a Phillips #000 screwdriver.
    • Remove the cover from the phone.
  9. Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using tweezers, carefully remove the earpiece speaker at the top of the phone.
    • When using metal tools, it is important to be gentle in order to not damage the device.
    • If needed, you can use a hair dryer to apply heat to the speaker and loosen the adhesive.
    • If needed, you may orient the tweezers to your liking, gripping the earpiece horizontally or vertically, while removing it.
  10. Samsung Galaxy A11 Display Assembly Replacement, Fingerprint Sensor: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement, Fingerprint Sensor: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement, Fingerprint Sensor: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a spudger, detach the ribbon cable connected to the fingerprint sensor.
    • Remove the fingerprint sensor from the device.
  11. Samsung Galaxy A11 Display Assembly Replacement, Motherboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 3 mm silver and black screws from the top of the device using a Phillips #000 screwdriver.
  12. Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a spudger, disconnect the two ribbon cables attached to the battery slot from the motherboard.
    • Disconnect the two longer ribbon cables near the bottom right corner of the motherboard.
    • Lift these cables up slightly to reveal a gap.
  13. Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a spudger, gently pry the motherboard up using the corner revealed in the previous step.
    • If needed, use a metal spudger as a sturdier alternative.
    • If using a metal spudger, it is important to be gentle in order to not damage any components of the device.
    • Remove the motherboard from the device.
  14. Samsung Galaxy A11 Display Assembly Replacement, Daughterboard: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement, Daughterboard: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement, Daughterboard: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the eight silver and black 3 mm screws from the speaker cover using a Phillips #000 screwdriver.
    • Remove the speaker cover from the device.
  15. Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a spudger, disconnect the antenna heads from the daughterboard.
    • Disconnect the ribbon cable from the daughterboard.
  16. Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using tweezers, gently pry the daughterboard from the device.
  17. Samsung Galaxy A11 Display Assembly Replacement, Vibration Motor: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A11 Display Assembly Replacement, Vibration Motor: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers, remove the vibrator motor from the device.
    • If needed, you can apply heat to loosen the adhesive from the motor.
  18. Samsung Galaxy A11 Display Assembly Replacement, Display Assembly: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The display assembly is separated from all other components and can be replaced.
Chloe Bulloch
crwdns2935283:009/04/24crwdne2935283:0
453 crwdns2915208:0crwdne2915208:0
Utah Tech University, Team 1-6, Crenshaw Fall 2024 crwdns2935289:0Utah Tech University, Team 1-6, Crenshaw Fall 2024crwdne2935289:0
UTAHTECH-CRENSHAW-F24S1G6
crwdns2936753:030crwdne2936753:0 103
crwdns2942667:0crwdne2942667:0 777
