Prereq for replacing the motherboard cover in your Samsung Galaxy A10.
Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole in the SIM card tray.
Press to eject the tray.
Remove the SIM card tray from the phone.
Insert an opening pick between the screen and the back cover on the bottom of the phone where the charging port is located.
Slide the opening pick to the bottom left corner to release the clips.
Slide the opening pick along the left edge to the top left corner of the phone, to release the clips.
Slide the opening pick from the top left corner to the top right corner to release the plastic clips.
Slide the opening pick from the top right corner to the bottom right corner to release the remaining clips.
Remove screws from the motherboard antenna cover.
3 Phillips #00, 3mm length.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use the tip of a spudger or tweezers to remove the antenna cover.
Remove screws from the motherboard cover.
There’s actually a 4th screw on the top middle of this cover. Took me and my wife several minutes to figure that one out.
Use the tip of a spudger or tweezers to remove the motherboard cover.
I have looked literally everywhere and nobody is covering the top motherboard 2 connectors w/ Ribbons on top the black squares one camera and the 1 to the right how does that 1 to the right connect with the ribbon please help thank you
