Samsung A10, A10s Micro USB Charging connector Replacement
crwdns2936621:0crwdne2936621:0
Remove the SIM Tray.
Use plastic tools to separate the back cover.
Remove the silver Phillips screws to be able to disassemble the motherboard shields.
Disconnect the battery.
Remove the screws and the charging board shield.
Disconnect the main flex cable and the coaxial antenna cables.
Remove the charging board.
Cover the microphone hole to prevent microphone damage.
Use hot air to remove the Micro USB connector.
Clean the tin and install the new charging connector.
crwdns2935229:016crwdne2935229:0
Waste of time unless you're obsessed with soldering. Just buy a complete board. Cheaper, easier and quicker.
Excelente Gracias por la información
Emilio Marcelino FELIX ALBERTO - crwdns2934203:0crwdne2934203:0
Me sirvió de mucho el tutorial, muy bien documentado con imágenes, útil hasta para personas que no tengan conocimientos técnicos. gracias.
