Samsung Galaxy A03s Screen Replacement
  1. Samsung Galaxy A03s Screen Replacement, Eject SIM card tray: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the sim card by inserting a sim card tool into the sim card tray hole.
  2. Samsung Galaxy A03s Screen Replacement, Remove back cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A03s Screen Replacement, Remove back cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A03s Screen Replacement, Remove back cover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This cover has a series of plastic clips that attach it to the frame. Use your opening tool to gently pry the plastic back cover off.
    • Be careful inserting your opening tool near the power button. This button contains a fingerprint sensor with a ribbon cable that’s attached to the back cover. Do not cut this cable while removing the back cover.
  3. Samsung Galaxy A03s Screen Replacement, Remove power button: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 2 plastic notches on the back cover hold the power button in place. Disconnect the power button from the back cover.
  4. Samsung Galaxy A03s Screen Replacement, Unfasten screws on camera lens bracket and loud speaker: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A03s Screen Replacement, Unfasten screws on camera lens bracket and loud speaker: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 18 screws secure the camera lens bracket and loud speaker. All screws are the same size. Use a Phillips screwdriver to remove the 18 screws securing the camera lens bracket and loud speaker.
  5. Samsung Galaxy A03s Screen Replacement, Remove camera lens bracket and loud speaker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A03s Screen Replacement, Remove camera lens bracket and loud speaker: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A03s Screen Replacement, Remove camera lens bracket and loud speaker: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your spudger to lift and remove the camera lens bracket and loud speaker.
  6. Samsung Galaxy A03s Screen Replacement, Disconnect battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A03s Screen Replacement, Disconnect battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery cable by using a spudger
  7. Samsung Galaxy A03s Screen Replacement, Disconnect and remove power button: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A03s Screen Replacement, Disconnect and remove power button: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your spudger to disconnect the power button ribbon cable. Remove the power button.
  8. Samsung Galaxy A03s Screen Replacement, Disconnect and remove mainboard cable: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A03s Screen Replacement, Disconnect and remove mainboard cable: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your spudger to disconnect and remove the mainboard flex cable.
  9. Samsung Galaxy A03s Screen Replacement, Disconnect and remove antenna cable: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A03s Screen Replacement, Disconnect and remove antenna cable: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to disconnect and remove the black antenna cable on the mainboard and charging board
  10. Samsung Galaxy A03s Screen Replacement, Remove mainboard and charging board: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A03s Screen Replacement, Remove mainboard and charging board: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your spudger to lift and remove mainboard and charging board
  11. Samsung Galaxy A03s Screen Replacement, Remove vibrate motor: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A03s Screen Replacement, Remove vibrate motor: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use heat and/or isopropyl alcohol to remove vibrate motor
  12. Samsung Galaxy A03s Screen Replacement, Remove volume button flex: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A03s Screen Replacement, Remove volume button flex: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use heat and/or isopropyl alcohol to remove volume button flex
  13. Samsung Galaxy A03s Screen Replacement, Remove earpiece speaker: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A03s Screen Replacement, Remove earpiece speaker: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use spudger to remove earpiece speaker
  14. Samsung Galaxy A03s Screen Replacement, Remove battery: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Plastic Cards
    $2.99
    • Use heat and isopropyl alcohol to remove the battery.
    • Be careful to not puncture the battery while removing it.
    • There's a lot of adhesive under this battery and it can be tricky to remove. You can slide a thin plastic card underneath the battery to help break the adhesive.
crwdns2935229:040crwdne2935229:0
Matea
crwdns2935283:005/05/23crwdne2935283:0
1,369 crwdns2915208:0crwdne2915208:0
Actually you guys are making it more complex and difficult than it needs to be or should ever have to be because I've repaired hundreds of Samsung Galaxy a03 s's and all Samsung Galaxy phones for that matter and the way you're going about in depth in detail and specific on a complete breakdown is too complex to be quite frankly honest with you you don't need to do all of this you're doing more work than what is really there honestly.
Harold Peterson - crwdns2934203:0crwdne2934203:0
Are you going to offer the more simple solutions or no?
Missjentri -
Yeah, so do a better job
Timothy Bradford -
Can you post the simplest was to do this?
Chuck -
No carga solo logo de temperatura
Alan Rivera - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 28
crwdns2936753:07crwdne2936753:0 181
crwdns2936753:030crwdne2936753:0 942
crwdns2942667:0crwdne2942667:0 24,166
