Use this guide to replace a defective Camera.
Insert plastic opening tool under back cover.
Apply pressure on tool while using a downward motion to pop off back cover.
Insert plastic opening tool under battery.
Pry battery out.
Pry the top cover upward to remove it from the phone.
Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
Insert plastic opening tool under top cover.
Using hand slide top cover away from phone.
Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
Insert plastic opening tool between back assembly and phone.
Pry the back assembly away from phone.
With plastic opening tool continue prying around the edge of the back assembly.
Pull back panel assembly away from main body.
Use the flat end of a spudger to disconnect the camera assembly cable.
