Use this guide to replace a defective Motherboard.
Insert plastic opening tool under back cover.
Apply pressure on tool while using a downward motion to pop off back cover.
Insert plastic opening tool under battery.
Pry battery out.
Pry the top cover upward to remove it from the phone.
Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
Insert plastic opening tool under top cover.
Using hand slide top cover away from phone.
Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
Insert plastic opening tool between back assembly and phone.
Pry the back assembly away from phone.
With plastic opening tool continue prying around the edge of the back assembly.
Pull back panel assembly away from main body.
Insert the pointed end of a spudger into the gap in the round housing frame.
Using spudger to remove vibrator remove from the adhesive.
Use the flat end of a spudger to remove vibrator cable from motherboard.
Use the flat end of a spudger to disconnect the camera assembly cable.
Insert the spudger under each corner ribbon cable and lift them out of the way.
Insert a plastic pry tool into the gap between motherboard and base of phone
Tilt the motherboard up carefully.
Use a spudger to pry the connector from the socket on the motherboard.
Lift motherboard from frame.
