Samsung Exhibit II 4G Loudspeaker Replacement
  1. Samsung Exhibit II 4G Loudspeaker Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
  2. Samsung Exhibit II 4G Loudspeaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert plastic opening tool under battery.
    • Pry battery out.
  3. Samsung Exhibit II 4G Loudspeaker Replacement, Top Rear Housing Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the top cover upward to remove it from the phone.
  4. Samsung Exhibit II 4G Loudspeaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the top cover.
  5. Samsung Exhibit II 4G Loudspeaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Exhibit II 4G Loudspeaker Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
  6. Samsung Exhibit II 4G Loudspeaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Exhibit II 4G Loudspeaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Exhibit II 4G Loudspeaker Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
  7. Samsung Exhibit II 4G Loudspeaker Replacement, Midframe: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
  8. Samsung Exhibit II 4G Loudspeaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert plastic opening tool between back assembly and phone.
    • Pry the back assembly away from phone.
  9. Samsung Exhibit II 4G Loudspeaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With plastic opening tool continue prying around the edge of the back assembly.
  10. Samsung Exhibit II 4G Loudspeaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull back panel assembly away from main body.
  11. Samsung Exhibit II 4G Loudspeaker Replacement, Loudspeaker: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Exhibit II 4G Loudspeaker Replacement, Loudspeaker: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Exhibit II 4G Loudspeaker Replacement, Loudspeaker: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Position Back Panel Assembly so the internal Loudspeaker unit is facing up.
    • With your index fingers and thumbs, grasp the Back Panel Assembly near the Loudspeaker.
    • Twist your palms inward to apply pressure against your index fingers.
    • The Loudspeaker will easily pop out.
David R
crwdns2935283:007/20/15crwdne2935283:0
1,152 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-3, Rowley SU 2015 crwdns2935289:0Eastern Washington University, Team 1-3, Rowley SU 2015crwdne2935289:0
EWU-ROWLEY-SU15S1G3
crwdns2942667:0crwdne2942667:0 350
