crwdns2959928:0crwdne2959928:0 ↓You will need to find a clean area to work in and have the necessary tools. Follow this guide to gain access to your cellphone's motherboard.
Spudger4.9
Remove the back battery cover.
Using a nylon spudger, remove the phone's battery.
Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver.
Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
Pull the antenna plug out of its socket.
Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
Pop the red hinged-release lever away from its ribbon. Then pull it out.
Peel the button sensor on the side of the motherboard off of the case.
Slightly pull up one side of the motherboard.
Pull the button/microphone plug out of its socket.
Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
You have successfully removed the motherboard from the phone.
