Samsung Eternity Digitizer and Screen Replacement
crwdns2942287:0crwdne2942287:0You will need to find a clean area to work in and have the necessary tools. Follow this guide to gain access to your cellphone's digitizer and screen.
crwdns2944105:0crwdne2944105:0
Remove the back battery cover.
Using a nylon spudger, remove the phone's battery.
Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver.
Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
Pull the antenna plug out of its socket.
Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
Pop the red hinged-release lever away from its ribbon. Then pull it out.
Peel the button sensor on the side of the motherboard off of the case.
Slightly pull up one side of the motherboard.
Pull the button/microphone plug out of its socket.
Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
You have successfully removed the motherboard from the phone.
Flip the phone over so you are looking at the front screen of the phone.
Use a small tool to pry the digitizer and screen (together) from the frame of the phone.
Next, carefully pull the digitizer away from the screen.
At this point you can replace either the screen or the digitizer.
You did not mention how to glue the digitizer to LCD. That is a very important step.
Do these steps also work for the Samsung Eternity 2?
Está mierda no sale
