You will need to find a clean area to work in and have the necessary tools. Follow this guide to gain access to your cellphone's antenna/speaker module.
Remove the back battery cover.
Using a nylon spudger, remove the phone's battery.
Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver.
Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Pop the antenna plug off of its socket with a pair of metal tweezers.
Peel the button sensor on the side of the motherboard off of the case.
Pop the speaker plug out of its socket.
Pry the antenna/speaker component out of its casing. You need to use a little force to get the piece to pop out.
You will now be able to replace the antenna/speaker module.
