Samsung Epix Motherboard Replacement
  1. Samsung Epix Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Just below the phone's camera, press the button and hold it
    • While the button is held down, slide the back panel off to remove it completely.
  2. Samsung Epix Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grasp the bottom corners of the battery with two fingers and gently lift.
    • Gently lift the battery and remove it from the phone.
  3. Samsung Epix Motherboard Replacement, Speakers: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using an iPod opening tool, remove the screw cover in the top left corner by lifting it up.
  4. Samsung Epix Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the six screws on the back of the phone. Three are evenly spaced on each side.
    • The upper right screw is 4.5mm while the rest are 6.5mm.
  5. Samsung Epix Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Epix Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the iPod opening tool into the seam on the side of the phone and turn it slightly to unhook the eight clips.
    • There are three clips on each side and two at the bottom of the phone.
  6. Samsung Epix Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
    • Be careful not to remove the front panel. It is still connected to the phone chassis by a ribbon cable in the bottom right corner of the motherboard.
  7. Samsung Epix Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the circular battery from the plastic holder by inserting a 1 mm flat head screwdriver under the battery where the red and blue wires connect and lifting gently.
    • Make sure the battery is still connected to the motherboard via the red and blue wires. This part does not have to be completely removed.
  8. Samsung Epix Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #00 screwdriver, unscrew the two 3.5mm screws that connect the speaker to the motherboard.
  9. Samsung Epix Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the iPod opening tool, unclip the red and black wires connecting the speaker to the motherboard.
    • Lift the speaker off of the motherboard.
    • The camera will remain attached to the phone when removing the speaker.
  10. Samsung Epix Motherboard Replacement, Motherboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using an iFixit opening tool, unlatch and disconnect the camera ribbon cable.
  11. Samsung Epix Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unlatch the LCD ribbon cable on the left side of the motherboard using the opening tool.
  12. Samsung Epix Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Epix Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unlatch and disconnect the two ribbon cables at the bottom center of the motherboard.
    • The two disconnected ribbon cables connect to the keypad and center button.
  13. Samsung Epix Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unlatch and remove the front panel ribbon cable located at the bottom right of the motherboard.
  14. Samsung Epix Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the opening tool to gently disconnect the microphone cable, also located at the bottom right of the motherboard.
  15. Samsung Epix Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the 3.5 mm screw at the bottom center of the motherboard.
  16. Samsung Epix Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the motherboard from the left side to begin removing it from the phone chassis.
    • A ribbon cable is still connected underneath on the right side.
  17. Samsung Epix Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the motherboard slightly to access the back, then use the opening tool to unlatch and disconnect the remaining ribbon cable.
    • Remove the motherboard.
Mark Wyse
crwdns2935283:004/19/11crwdne2935283:0
62 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 15-15, Regan Spring 2011 crwdns2935289:0Cal Poly, Team 15-15, Regan Spring 2011crwdne2935289:0
CPSU-REGAN-S11S15G15
crwdns2942667:0crwdne2942667:0 1,646
