Samsung Epix LCD Display Replacement
  1. Samsung Epix LCD Display Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Just below the phone's camera, press the button and hold it
    • While the button is held down, slide the back panel off to remove it completely.
  2. Samsung Epix LCD Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grasp the bottom corners of the battery with two fingers and gently lift.
    • Gently lift the battery and remove it from the phone.
  3. Samsung Epix LCD Display Replacement, LCD Display: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber screw cover in the top left corner by prying upwards with an opening tool.
  4. Samsung Epix LCD Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the six screws on the back of the phone.
    • The upper right screw is 4.5 mm and the others are 6.5 mm.
  5. Samsung Epix LCD Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Epix LCD Display Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening tool along the seam on the side of the phone and turn it slightly to unhook the eight clips.
    • There are three clips on each side and two at the bottom of the phone.
  6. Samsung Epix LCD Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
    • Be careful not to remove the front panel. It will still be connected to the phone chassis by a ribbon cable on the motherboard.
  7. Samsung Epix LCD Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using an opening tool, undo the ZIF connector halfway up the right side.
    • Carefully remove ribbon cable.
  8. Samsung Epix LCD Display Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front faceplate by lifting it off of the phone chassis.
  9. Samsung Epix LCD Display Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the opening tool, unlatch the LCD ribbon cable.
  10. Samsung Epix LCD Display Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using an opening tool or spudger, pry under the lower left and right corners of the LCD screen.
    • The LCD is held in place to the chassis with adhesive strips.
    • Do not pry excessively hard. You may damage the circuitry on the back of the LCD.
  11. Samsung Epix LCD Display Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the LCD display out from phone chassis.
Mark Wyse
crwdns2935283:004/19/11crwdne2935283:0
62 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 15-15, Regan Spring 2011 crwdns2935289:0Cal Poly, Team 15-15, Regan Spring 2011crwdne2935289:0
CPSU-REGAN-S11S15G15
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 1,997
