Samsung Epix Keyboard Replacement
  1. Samsung Epix Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Just below the phone's camera, press the button and hold it
    • While the button is held down, slide the back panel off to remove it completely.
  2. Samsung Epix Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grasp the bottom corners of the battery with two fingers and gently lift.
    • Gently lift the battery and remove it from the phone.
  3. Samsung Epix Keyboard Replacement, Keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic prying tool, remove the screw cover in the top left corner of the phone by lifting it up.
    • Be gentle
  4. Samsung Epix Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #00 screwdriver to remove the six screws on the back of the phone.
    • Three of the screws are evenly spaced on the left and right side on the back of the phone.
    • The upper right screw is 4.5mm while the rest are 6.5mm.
  5. Samsung Epix Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Epix Keyboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the prying tool into the seam on the side of the phone and turn it slightly. Do this for each of the eight clips to unhook them
    • There are three clips on each side and two at the bottom of the phone.
  6. Samsung Epix Keyboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all eight of the clips have been unhooked, lift the back panel gently off of the phone.
    • Be careful and do not attempt to remove the front panel. It is still connected to the phone's chassis by a ribbon cable which is located in the bottom right side of the motherboard.
  7. Samsung Epix Keyboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic prying tool, unlatch the ribbon cable located in the lower right corner of the motherboard.
    • Carefully disconnect the ribbon cable.
  8. Samsung Epix Keyboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift and remove the front faceplate
    • Exercise caution
  9. Samsung Epix Keyboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grasp the rubber keyboard in the corner with your fingers and lift to remove it.
    • Lift it and gently take it out the frame to remove it.
Chris
crwdns2935283:004/20/11crwdne2935283:0
32 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 15-15, Regan Spring 2011 crwdns2935289:0Cal Poly, Team 15-15, Regan Spring 2011crwdne2935289:0
CPSU-REGAN-S11S15G15
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 1,710
