Samsung Epic 4G Touchscreen Replacement
    1. Samsung Epic 4G Touchscreen Replacement, Phone Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide your fingernail along the edge of the device and pull at the plastic backing.
      • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
    2. Samsung Epic 4G Touchscreen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull at the plastic backing gently to remove it after hearing the snap sound.
    1. Samsung Epic 4G Touchscreen Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the battery from the device by pulling the battery edge upwards.
    1. Samsung Epic 4G Touchscreen Replacement, Removing the Memory Card:: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the memory card on the upper right-hand corner of the device.
      • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
    2. Samsung Epic 4G Touchscreen Replacement, Removing the Back Housing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Epic 4G Touchscreen Replacement, Removing the Back Housing: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
      • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
      • While separating the two components, most of the buttons (including the power button) will fall out.
    3. Samsung Epic 4G Touchscreen Replacement, Removing the Power Button: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Epic 4G Touchscreen Replacement, Removing the Power Button: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the power button using tweezers if it did not fall out in the previous step.
      • At this point, you can replace the power button with a new one from a manufacturer.
    1. Samsung Epic 4G Touchscreen Replacement, Micro USB Port: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the white cable along the right side of the device (next to the battery housing) using the nylon spudger.
      • Pull out both ends of the white cable. They will easily snap out of place without excessive tension.
      • Do not rip the white cables out of the device.
    2. Samsung Epic 4G Touchscreen Replacement, Removing the Antenna Assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Epic 4G Touchscreen Replacement, Removing the Antenna Assembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the screw holding the antenna assembly in place using a Tri-Point Y0 screwdriver.
      • Snap the antenna assembly out of the device gently using your fingers.
    3. Samsung Epic 4G Touchscreen Replacement, Removing the Flex Cable: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Epic 4G Touchscreen Replacement, Removing the Flex Cable: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pry the flex cable from the top of the phone by carefully using a nylon spudger.
      • Repeat this step for the larger flex cable located on the left side of the device below the smaller one.
    4. Samsung Epic 4G Touchscreen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift and remove the motherboard from the device.
      • The USB port is located at the top of the motherboard. At this point, replace the port with a new one from a manufacturer.
    1. Samsung Epic 4G Touchscreen Replacement, Camera Lens: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove and replace the camera lens with a new one from a manufacturer.
    1. Samsung Epic 4G Touchscreen Replacement, Keyboard: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Epic 4G Touchscreen Replacement, Keyboard: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the white label sticker.
      • Remove the four screws on the left side of the device with a small Phillips screwdriver.
      • Two of the screws are found behind the white label, and two are found directly above the label.
    2. Samsung Epic 4G Touchscreen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Epic 4G Touchscreen Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Epic 4G Touchscreen Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift up and loosen the metallic silver trim on the perimeter of the phone using a nylon spudger.
      • Carefully remove the gray mid-plate with the spudger.
      • Take extra caution to not destroy the QWERTY keyboard, which lies directly behind the mid-plate. Do not slide open the phone at this time.
      • The mid-plate should be completely removed from the keyboard and separated from the device.
      • At this point, you may remove the original QWERTY keyboard and install a replacement keyboard. Installation is the reverse of removal.
    1. Samsung Epic 4G Touchscreen Replacement, Removing the Keypad Housing:: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Epic 4G Touchscreen Replacement, Removing the Keypad Housing:: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the four Phillips #00 screws on the keypad housing.
      • Carefully pull off the keypad housing while avoiding the flex cable.
    2. Samsung Epic 4G Touchscreen Replacement, Removing the Slide Mechanism:: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Epic 4G Touchscreen Replacement, Removing the Slide Mechanism:: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two black screw covers using the spudger.
      • Carefully unscrew the four corner screws using the Phillips screwdriver.
    3. Samsung Epic 4G Touchscreen Replacement, Removing the Slide Mechanism (continued):: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Epic 4G Touchscreen Replacement, Removing the Slide Mechanism (continued):: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pry off the slide mechanism using the flat edge of the spudger.
      • Be careful not to push the spudger too far in since it can damage the phone.
      • Carefully separate the slide mechanism while avoiding the flex cable.
    4. Samsung Epic 4G Touchscreen Replacement, Removing the Flex Cable:: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Epic 4G Touchscreen Replacement, Removing the Flex Cable:: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Epic 4G Touchscreen Replacement, Removing the Flex Cable:: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Carefully remove all the blue tape using the tweezers.
      • Unsnap and pull out the large portion of the flex cable.
      • Pull off the front face camera using the tweezers.
    5. Samsung Epic 4G Touchscreen Replacement, Removing the Flex Cable (continued):: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Epic 4G Touchscreen Replacement, Removing the Flex Cable (continued):: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Epic 4G Touchscreen Replacement, Removing the Flex Cable (continued):: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Carefully pull out the smaller portion of the flex cable using the tweezers.
      • Pop out the last part of the flex cable using the flat edge of the spudger.
      • Remove the flex cable completely.
    6. Samsung Epic 4G Touchscreen Replacement, Separating the Screen:: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Epic 4G Touchscreen Replacement, Separating the Screen:: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Epic 4G Touchscreen Replacement, Separating the Screen:: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull out the touch sensor flex cable using the tweezers.
      • Fold back the strip of white tape using the tweezers.
      • Pop out the speaker assembly using the spudger.
    7. Samsung Epic 4G Touchscreen Replacement, Separating the Screen (continued):: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Epic 4G Touchscreen Replacement, Separating the Screen (continued):: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully pull apart the frame and the screen.
      • You can now replace the LCD screen.
Andrew Cunningham
crwdns2935283:010/03/12crwdne2935283:0
273 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 24-25, Regan Fall 2012 crwdns2935289:0Cal Poly, Team 24-25, Regan Fall 2012crwdne2935289:0
CPSU-REGAN-F12S24G25
crwdns2935297:084crwdne2935297:0
crwdns2936753:030crwdne2936753:0 109
crwdns2942667:0crwdne2942667:0 5,630
