Samsung Epic 4G Power Button Replacement
  1. Samsung Epic 4G Power Button Replacement, Phone Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide your fingernail along the edge of the device and pull at the plastic backing.
    • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
  2. Samsung Epic 4G Power Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull at the plastic backing gently to remove it after hearing the snap sound.
  3. Samsung Epic 4G Power Button Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the device by pulling the battery edge upwards.
  4. Samsung Epic 4G Power Button Replacement, Removing the Memory Card:: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the memory card on the upper right-hand corner of the device.
    • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
  5. Samsung Epic 4G Power Button Replacement, Removing the Back Housing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Epic 4G Power Button Replacement, Removing the Back Housing: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
    • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
    • While separating the two components, most of the buttons (including the power button) will fall out.
  6. Samsung Epic 4G Power Button Replacement, Removing the Power Button: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Epic 4G Power Button Replacement, Removing the Power Button: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the power button using tweezers if it did not fall out in the previous step.
    • At this point, you can replace the power button with a new one from a manufacturer.
Andrew Cunningham
crwdns2935283:010/03/12crwdne2935283:0
273 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 24-25, Regan Fall 2012 crwdns2935289:0Cal Poly, Team 24-25, Regan Fall 2012crwdne2935289:0
CPSU-REGAN-F12S24G25
crwdns2942667:0crwdne2942667:0 2,354
