Samsung Epic 4G Micro USB Port Replacement
  1. Samsung Epic 4G Micro USB Port Replacement, Phone Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide your fingernail along the edge of the device and pull at the plastic backing.
    • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
  2. Samsung Epic 4G Micro USB Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull at the plastic backing gently to remove it after hearing the snap sound.
  3. Samsung Epic 4G Micro USB Port Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the device by pulling the battery edge upwards.
  4. Samsung Epic 4G Micro USB Port Replacement, Removing the Memory Card:: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the memory card on the upper right-hand corner of the device.
    • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
  5. Samsung Epic 4G Micro USB Port Replacement, Removing the Back Housing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Epic 4G Micro USB Port Replacement, Removing the Back Housing: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
    • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
    • While separating the two components, most of the buttons (including the power button) will fall out.
  6. Samsung Epic 4G Micro USB Port Replacement, Removing the Power Button: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Epic 4G Micro USB Port Replacement, Removing the Power Button: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the power button using tweezers if it did not fall out in the previous step.
    • At this point, you can replace the power button with a new one from a manufacturer.
  7. Samsung Epic 4G Micro USB Port Replacement, Micro USB Port: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the white cable along the right side of the device (next to the battery housing) using the nylon spudger.
    • Pull out both ends of the white cable. They will easily snap out of place without excessive tension.
    • Do not rip the white cables out of the device.
  8. Samsung Epic 4G Micro USB Port Replacement, Removing the Antenna Assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Epic 4G Micro USB Port Replacement, Removing the Antenna Assembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw holding the antenna assembly in place using a Tri-Point Y0 screwdriver.
    • Snap the antenna assembly out of the device gently using your fingers.
  9. Samsung Epic 4G Micro USB Port Replacement, Removing the Flex Cable: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Epic 4G Micro USB Port Replacement, Removing the Flex Cable: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the flex cable from the top of the phone by carefully using a nylon spudger.
    • Repeat this step for the larger flex cable located on the left side of the device below the smaller one.
  10. Samsung Epic 4G Micro USB Port Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove the motherboard from the device.
    • The USB port is located at the top of the motherboard. At this point, replace the port with a new one from a manufacturer.
crwdns2935229:08crwdne2935229:0
Andrew Cunningham
crwdns2935283:010/03/12crwdne2935283:0
273 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 24-25, Regan Fall 2012 crwdns2935289:0Cal Poly, Team 24-25, Regan Fall 2012crwdne2935289:0
CPSU-REGAN-F12S24G25
My phone doesn’t have a memory card. At least, not that I can see. What should I do?
Joshua Campbell - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,482
