Samsung Droid Charge SIM Card Port Replacement
  1. Samsung Droid Charge SIM Card Port Replacement, Rear Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open up the back case on the phone from the groove in the bottom of the phone.
    • You can do this by inserting a fingernail or similarly thin object into the groove and pulling up with mild force.
  2. Samsung Droid Charge SIM Card Port Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Below the left part of the bottom of the battery area there will be a groove large enough to fit in a finger or screw driver head.
    • Use the groove to lever out the battery gently, in order to not damage either the battery or phone. Store the battery in a safe place.
  3. Samsung Droid Charge SIM Card Port Replacement, microSD: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the SD card further into its metal slot until you hear a click.
    • Release the card, and it should automatically eject itself.
    • Remove the SD card.
  4. Samsung Droid Charge SIM Card Port Replacement, SIM Card: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the SIM card out of its casing by pushing on it and sliding it upward.
  5. Samsung Droid Charge SIM Card Port Replacement, SIM Card Port: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the back cover.
    • Remove the two 5mm screws with a small Phillips head screwdriver.
  6. Samsung Droid Charge SIM Card Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Removal of the back half of the casing.
    • Using a thin plastic flat head screw driver, or similar item. On the side of the phone insert the thin edge into the visible split between the 2 halves of the phone.
    • Use a prying motion to lift the casing up. This will separate the phone casing.
    • Repeat this motion all around the screen edge until the casing pops off.
  7. Samsung Droid Charge SIM Card Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Release the volume button flex cable on the right.
    • Release the pop connector on the motherboard located to the left of the SIM card port.
  8. Samsung Droid Charge SIM Card Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Droid Charge SIM Card Port Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Your SIM card port is now unattached.
    • Remove SIM card port from motherboard.
Lucas Carter
crwdns2935283:009/27/12crwdne2935283:0
172 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 15-44, Forte Fall 2012 crwdns2935289:0Cal Poly, Team 15-44, Forte Fall 2012crwdne2935289:0
CPSU-FORTE-F12S15G44
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 2,446
