Samsung DVD-HD850 Player Fuse Replacement
  1. Samsung DVD-HD850 Player Fuse Replacement, Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • with the front of the device facing you, turn the device 180 degrees so the back panel of the device is facing you
  2. Samsung DVD-HD850 Player Fuse Replacement, Locate and remove screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • locate the three (3) screws on the back panel of the device that are implanted in the device
    • to remove the screws, use the tool(s) listed above (right underneath the introduction) and twist the screws counter-clockwise to remove them from the device
  3. Samsung DVD-HD850 Player Fuse Replacement, Remove Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • to remove the cover of the device, pull the cover towards the back of the device until it is completely removed so you can see the insides of the device
  4. Samsung DVD-HD850 Player Fuse Replacement, Locate the Circuit Board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure your device is unplugged before you try to do the following steps to avoid electrocution
    • It is recommended to buy the new power fuse before proceeding with this guide. To buy a power fuse online you can click on the name of the fuse under the "relevant parts" section on the top of this page and it will guide you to a website to buy one
    • With the back panel of the device facing towards you, locate the circuit board inside the device
  5. Samsung DVD-HD850 Player Fuse Replacement, Locate the Power Fuse: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the power fuse on the bottom left of the circuit board
  6. Samsung DVD-HD850 Player Fuse Replacement, Remove the Power Fuse: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To Remove the power fuse from the circuit board, gently pull up on the fuse to remove it from the metal clips
    • The power fuse is very delicate so do not put much force into pulling it from the clips
  7. Samsung DVD-HD850 Player Fuse Replacement, Insert the new Power Fuse: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the old power fuse, put in the new fuse by gently pushing the fuse into the metal clips until it clicks into place
    • The best way to put the new fuse in is by grabbing both ends of the fuse and pushing it in from the ends. Avoid pushing it in from the middle of the fuse to prevent it from breaking
    • If done correctly you should now have full power back in your device!
    • Do not try to power the device on before reassembling the device first
Devon Clements
crwdns2935283:010/21/14crwdne2935283:0
228 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-6, Duarte Fall 2014 crwdns2935289:0UMass Dartmouth, Team 1-6, Duarte Fall 2014crwdne2935289:0
UMASSD-DUARTE-F14S1G6
crwdns2942667:0crwdne2942667:0 4,929
