Caution: All alteration or modifications are the users responsibility, and not of the guide creator. These steps are only recommended if not under warranty or if a solution has not yet been found.
Find and locate the disk tray it is located top right hand side of the component when the back of the device ( dvd player ) is facing you.
Locate and gently remove the data strips on the tray. There are three in total, two on the left hand side and one on the right.
As noted by the red circles, locate and remove the screws one at a time
After removing the clips slowly incline the disk drive towards you and unclip it from the two (2) brackets located on the top
Congrats! You have sucessfully have taken out the disk drive
