This guide will show how to remove the camera's lens.
Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
Remove the back case of the camera carefully.
The covers are attached with very small tabs around the cover perimeter. A very small blade screwdriver is helpful in prizing the covers apart and off.
Remove the front case of the camera.
Remove the front LCD screen from the front case next to the lens.
Remove the blue button control from its position next to the LCD screen.
Pull the ribbon cable to disconnect the blue button control from the camera.
Remove the back LCD screen from its place carefully.
samsung es90 lcd Where to call the address
I live in Bangladesh
The white LCD is attached to the housing with sticky tape. Again a small blade screwdriver is helpful to CAREFULLY pry it out.
Where can i find a replacement lcd screen?
Flip the black tab where the back LCD screen connects to the circuit board.
Pull the tape connection to disconnect the back LCD screen from the circuit board.
Unscrew the 3 silver #0 Phillips 4.45mm screws from the circuit board cover
Remove the circuit board cover
Flip the first black tab connecting the lens to the circuit board
Flip the second black tab connecting the lens to the circuit board
Push the lens out from the front to remove it from the camera
crwdns2935229:05crwdne2935229:0
pourquoi ne pas aussi montrer comment demonter le lens de samsung dv300f
Only one screw on bottom of camera
John Petralito - crwdns2934203:0crwdne2934203:0
