Samsung DV300F Lens Replacement
  1. Samsung DV300F Lens Replacement, Front and Rear Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung DV300F Lens Replacement, Front and Rear Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung DV300F Lens Replacement, Front and Rear Casing: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
    Only one screw on bottom of camera
    John Petralito - crwdns2934203:0crwdne2934203:0
  2. Samsung DV300F Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung DV300F Lens Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back case of the camera carefully.
    The covers are attached with very small tabs around the cover perimeter. A very small blade screwdriver is helpful in prizing the covers apart and off.
    JM Johnson - crwdns2934203:0crwdne2934203:0
  3. Samsung DV300F Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung DV300F Lens Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung DV300F Lens Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the front case of the camera.
    • Remove the front LCD screen from the front case next to the lens.
  4. Samsung DV300F Lens Replacement, Back Button Control: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung DV300F Lens Replacement, Back Button Control: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the blue button control from its position next to the LCD screen.
    • Pull the ribbon cable to disconnect the blue button control from the camera.
  5. Samsung DV300F Lens Replacement, Back LCD Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back LCD screen from its place carefully.
    samsung es90 lcd Where to call the address
    ianam73 73 - crwdns2934203:0crwdne2934203:0
    The white LCD is attached to the housing with sticky tape. Again a small blade screwdriver is helpful to CAREFULLY pry it out.
    Where can i find a replacement lcd screen?
    Jason Bills - crwdns2934203:0crwdne2934203:0
  6. Samsung DV300F Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung DV300F Lens Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the black tab where the back LCD screen connects to the circuit board.
    • Pull the tape connection to disconnect the back LCD screen from the circuit board.
  7. Samsung DV300F Lens Replacement, Lens: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung DV300F Lens Replacement, Lens: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 3 silver #0 Phillips 4.45mm screws from the circuit board cover
    • Remove the circuit board cover
  8. Samsung DV300F Lens Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung DV300F Lens Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the first black tab connecting the lens to the circuit board
    • Flip the second black tab connecting the lens to the circuit board
    • Push the lens out from the front to remove it from the camera
crwdns2935229:05crwdne2935229:0
Timothy Gordon
crwdns2935283:003/23/15crwdne2935283:0
820 crwdns2915208:0crwdne2915208:0
Baylor, Team 5-10, Williams Spring 2015 crwdns2935289:0Baylor, Team 5-10, Williams Spring 2015crwdne2935289:0
BU-WILLIAMS-S15S5G10
pourquoi ne pas aussi montrer comment demonter le lens de samsung dv300f
nouzalek - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,579
