crwdns2959928:0crwdne2959928:0 ↓This guide will show how to remove the camera's lens.
Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
Remove the back case of the camera carefully.
Remove the front case of the camera.
Remove the front LCD screen from the front case next to the lens.
Remove the blue button control from its position next to the LCD screen.
Pull the ribbon cable to disconnect the blue button control from the camera.
Remove the back LCD screen from its place carefully.
Flip the black tab where the back LCD screen connects to the circuit board.
Pull the tape connection to disconnect the back LCD screen from the circuit board.
Unscrew the 3 silver #0 Phillips 4.45mm screws from the circuit board cover
Remove the circuit board cover
Flip the first black tab connecting the lens to the circuit board
Flip the second black tab connecting the lens to the circuit board
Push the lens out from the front to remove it from the camera
pourquoi ne pas aussi montrer comment demonter le lens de samsung dv300f
nouzalek - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
