crwdns2959928:0crwdne2959928:0 ↓This guide will show how to remove the Back LCD Screen.
Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
Remove the back case of the camera carefully.
Remove the front case of the camera.
Remove the front LCD screen from the front case next to the lens.
Remove the back LCD screen from its place carefully.
Flip the black tab where the back LCD screen connects to the circuit board.
Pull the tape connection to disconnect the back LCD screen from the circuit board.
crwdns2935229:05crwdne2935229:0
